1975 fxe
1975 fxe
Hello everyone, I am a new member here so excuse my greenness here. I have been a Harley rider for many years. Recently bought a 1975 superglide fxe, bringing it back to life after sitting for 15 years. My one question ❔ is how spacers are required for. The rear axle, I think I have the wrong ones in as I see the rear wheeloff centre a bit. Parts manual shows a very vague description. I have 2 diffent spacers on now and I am thinking this is. Incorrect. Can anyoneb shed some light thanks
Received 1,512 Likes
s-glide76 (07-14-2019)
Received 3,222 Likes
Then there is the rear axle spacer (#41595-73). This spacer will only fit between the swingarm and the wheel braring spacer on the left side.
Pics would help when you state the wheel is a "bit" off center.
My 78 FXE is a "bit" off.
I pulled the chain guard to make sure the chain was running true; made sure the rear axle was aligned properly, know for sure I have the correct OEM spaces and components. Probably out by at most 1/16 to 1/8 inch. Rides and tracks fine. Welcome to AMF
Ah staring to make sense, I believe I know what is happening, I am not running bike yet but I think the rear wheel has tiomany spacers, has the left side however it has a thinner washer on right did (brake side) which causes alignment problem and break rotor tightness. I thought there was no need for smaller spacer on right. And of course I have the 2 bearing spacers inside of seals correctly, I looked at a rear axle kit also on Jand P cycles and they only show this one spacer I think I may have this solved, will try to post pics, thank you very much.
johnson32
Wheels/Tires
07-10-2014 09:26 AM
forever 2 wheels
Panhead
02-03-2013 08:01 PM
LouEyez
09-12-2010 09:05 AM
