Why wouldn’t this work?
Old Jul 22, 2020 | 04:14 PM
ChopSticks's Avatar
ChopSticks
Default Why wouldn’t this work?
Background: think it’s kind of silly that Harley has placed the ignition and fork lock in separate places on the TC softail (maybe just ignition placement is foolish but nonetheless)
Objective: only requiring forks to be locked
Proposed solution: adding a switch/button/relay in the ground somewhere.
Phase 2 upgrade: fob/magnetic activated?
Alright so looking at the TC softail wiring diagram, looks like the keyed ignition allows the ignition to be switched into ACC and ON modes. All ON does is grounds the speedo, fuel gauge, lights/hand control, fuel pump and various other sensors to the main harness. So if I was to tap in a relay or switch into that one specific wire would this essentially work? Not sure if anything else would be left on or need to be considered when tapping this one wire (doesn’t look so based on wiring diagram)
the bike will always be in ON mode at the ignition **** (unlocked) but wouldn’t actually be ON until the switch/button/relay is actually activated somewhere on the bike... so essentially I can just deactivate the switch, lock the forks, and walk away?
also figured it might potentially be added safety from thieves that would just drill/brake the fork and ignition anyways?
as for the Phase 2, I know motogadget actually uses a keyless fob option but not sure if their m unit is required or can be done standalone and just used in replacement of the switch? Motogadget also has a small “pill” size fob that other riders have been known to sew into their gloves so all that needs to be done is forks unlocked, then gloves waved over a hidden spot with the receiver
or am I just thinking too out of the box here? Does the CANBUS system cause any issue for this?
Old Jul 23, 2020 | 07:38 PM
ChopSticks's Avatar
ChopSticks
After looking at it a bit more I’m starting to think the CANBUS will be an issue? I notice drag specialties makes an aftermarket ignition **** that is identical to the stock but they have three prongs that need to be connected (which makes sense for ACC/ON/GROUND) vs the two wire plug from the stock HD one...
Old Jul 23, 2020 | 08:36 PM
Since 1968's Avatar
Since 1968
Not sure what problem you're solving. The ignition and kill switches worked just fine on my twin cams. Motivated thieves will use 4 guys and two poles through your wheels and shove it into a cube van. Maybe Fatboy wheels would help?
VA_Larry
Nov 12, 2022 03:41 PM
HemiOrange
Jan 18, 2011 08:28 AM
crawfordcl
Sep 15, 2010 10:52 AM
jay3yzfr6
Aug 31, 2010 02:21 PM
hdfatboy54
Mar 23, 2008 03:51 PM
