Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   General Harley Davidson Chat (https://www.hdforums.com/forum/general-harley-davidson-chat-29/)
-   -   Installing idle/throttle cable's (https://www.hdforums.com/forum/general-harley-davidson-chat/19948-installing-idle-throttle-cables.html)
KBES BAGGER Jan 26, 2006 02:29 AM
I have done this about 4 times now it is not all that bad, however I have always pulled the tank off to do the swap. I figured this time I will ask around and see if anybody else has a better, less time and labor consuming way of doing it? This is going on an '06 RKC in case yall wanna know for some reson or another. Thanks for your help,
KB
04RoadKing Jan 27, 2006 12:23 PM
RE: Installing idle/throttle cable's
I did mine without taking the tank off. It was pretty easy, I used a coat hanger to snake the cables under the tank. The hardest part was hooking up the cable to the carb. Good luck.
Tim Jan 27, 2006 11:15 PM
Just did mine on a Sportster, only removed the AC to make it easier. Tim
DDDeepdiver Jan 28, 2006 10:08 AM
when i changed mine i unbolted the tank lifted it up enough to see the clamps and but a wedge under it to hold it up. I tied a piece of
mono fishing line to the end of the old cable and pulled it out. i than had the mono to use as a fish to pull the new one back through. I
tied the mono to the new cable and just pulled it back through it was very easy. I also put some tape around the mono to make sure it didnt pull off.
KBES BAGGER Jan 28, 2006 01:20 PM
I think this is how I am gonna do it this time. I think I will use some 14G wire instead of fishing line, its a little stiffer and might make it a little easier, or mabye harder.... We'll see. The other times I have done this I was doing other stuff to so I just completly removed the tank, plus I was bored out of my mind and it was somthing to do.
KB
ORIGINAL: DDDeepdiver
© 2026 MH Sub I, LLC dba Internet Brands
