Bump start?
Old Apr 4, 2008 | 09:52 AM
fxrer's Avatar
fxrer
Default Bump start?
When unloading my ’88 FXR (with S&S Super E) in Daytona a month ago, after a long cold winter and trailer ride from PA, the battery was dead. So, coasting down the driveway, I just ‘bump started’ it, like I have for years. The motor caught and ran fine once warm. Three of the other guys with me, all with EFI models (’05 FXD, ’03 FLHTC, and ’07 FXSTF), all wondered out loud “Could we bump start ours, too, in an emergency?”
My answer was “No, because there would be no juice to run the fuel pump, and thus no fuel to the injectors.”
Asssuming a dead battery, was I correct?
Old Apr 4, 2008 | 10:10 AM
dhoward's Avatar
dhoward
Default RE: Bump start?
Dead battery, no.
Enough juice to run FP and ECM but not enough to crank, yes.
Old Apr 4, 2008 | 10:14 AM
Silverearl's Avatar
Silverearl
If they can get it started it would not run but a minute or two. The fuel line will drain and then you are in trouble cause the battery would be dead and so will the pump. The computer will sence no fuel and shut it down. Seen it tried and what a mistake it was..
Old Apr 4, 2008 | 10:40 AM
RoadKingRon1's Avatar
RoadKingRon1
Wouldn't there be enough juice once it starts to keep it running?
Interesting to know in case I leave my lights on again.....[:@]
Old Apr 4, 2008 | 10:55 AM
DeJavu's Avatar
DeJavu
The older, non computer, alternator bikes will bump cause the alt jumps volts up when it spins. Although not enough juice from batt to use starter, they will start and run once bumped. I don't know how the EFI bikes work.
Old Apr 4, 2008 | 11:08 AM
Da Gumpmeister's Avatar
Da Gumpmeister
Uhhhh, carry a spare battery?
Just "kick" the damm thing. Oh, never mind, I forgot, we are in the 21st century. Instead of kicking it, take out the cell phone and call AAA or the dealer. DeJavu, me and the rest of the "dummies", will kick.
Another ? I have, do Harleyselectronics "shut down" on low voltage? In other words, would the "puter" even"fire" the plugs with low voltage? My Mallory will "shut down" when the voltage gets too low. I forgot to "polarize" my generator one time, and ran with the lights on, batt voltage got too low, and electronic ign shut down, but still had "REAL" dimlights. Anyone know 'bout the "new" ones?
Old Apr 4, 2008 | 11:21 AM
DeJavu's Avatar
DeJavu
Found out about the alt voltage thing when my chopper was new. The engine was tight and the kicker just wouldn't start it, period. A quick bump and it would fire on the first TDC. Freaked a few "experts".
Put a meter on it, taped to tank and saw the volts at 12.5 while kicking, but when bumped the volts shot up to 14 real quick. Now that it's broke in it's 2 primes and 1 kick cold. 1 kick warm, just like it's supposed to.
Old Apr 4, 2008 | 12:15 PM
maxum96's Avatar
maxum96
ORIGINAL: dhoward
Dead battery, no.
Ditto for FI bikes.
Old Apr 4, 2008 | 03:28 PM
wdg's Avatar
wdg
thanks for the information learned something new
Old Apr 4, 2008 | 06:09 PM
dog155's Avatar
dog155
I believe the ECU needs approx 9 volts to even work.Don't quote me.
Slideshow: Harley-Davidson's new RMCR concept revives the caf racer formula with modern hardware-and it may be exactly the reset the company needs.
