Is this normal?
Old Feb 10, 2009 | 06:52 AM
turczytj's Avatar
turczytj
No, no popping at all. Because there is no popping on decel, the blueing pipes can be considered ok?
Old Feb 10, 2009 | 06:56 AM
sniper77's Avatar
sniper77
Blue is good, now stop looking under the heat shields and RIDE
Old Feb 10, 2009 | 11:34 AM
xmarine's Avatar
xmarine
Yall correct me if I'm wrong but.............
Blue = LEAN (not good, too much HEAT)
Gold = RICH ( more fuel, less heat, fuel COOLS)
just sayin
xmarine
Old Feb 10, 2009 | 11:43 AM
oldairboater's Avatar
oldairboater
Mileage is too good for me. I would still suspect the bike is lean unless you live at a altitude a lot higher than sea level. At sea level I am getting under 40 mpg before mods in both bikes. After stage one my mileage went to 39 mpg on the 03 Heritage. After cams it went to 34 mpg. My carbed 98 evo gets 37 mpg. It is stock with fatter jetting. Check your plugs, they will tell. Antisieze your plugs while you have them out and only check them on a cold engine if possible.****** Lean is mean but rich last forever.******
Old Feb 10, 2009 | 12:56 PM
turczytj's Avatar
turczytj
what will the spark plug look like if the engine is running too lean?
Old Feb 10, 2009 | 01:10 PM
Kabear's Avatar
Kabear
To lean they will be "White", they should look like they are slightly "rusted". Plug color can be difficult without a chart. Some additives will turn the plugs a brownish color.
As long as the tip isn't melted you are probably ok.
OldAirboat: Man that is bad mileage, My 85 Evo gets 45mpg and my 02 TwinCam gets 50 mpg and that is around town. Both engines are Carbs.
Pitbull_Dallas
Aug 20, 2014 02:45 PM
jam436
May 18, 2013 12:25 AM
agove
Feb 15, 2013 05:04 AM
osb
Jun 5, 2012 02:26 PM
ultra2006
Feb 7, 2007 09:08 AM
