Bad Ass Hot Rod!
Received 1,310 Likes
If you look at the forks they have a pivot by the lower triple clamp. This where the forks pivot forward and that action is transfered to the shock. It is a horrible design because the wheel base gets longer as the front wheel compresses. Also when you hit the brake it causes the front lift and the wheel base to get shorter. This wkeel base length change will also make it unstable in bumpy corners. People try so hard to reinvent the wheel. If it works dont f*** with it, this bike would look so much better with some nice inverted forks so it still has the trick look to it. Maybe some nice billet wheels would look better also.
The price is absolutely ridiculous, the forks look like they tried to use an Earl's design but I can't see how the geometry would make them comfy let alone safe.
