JB Weld or Like?
JB Weld or Like?
Whats the best repair you have ever made with JB Weld (That lasted)?
Whats the worse repair that you have ever made with JB Weld (That failed)?
You can also name similar products success of failure stories.
i got a "hot" faucett **** on my homeade pipes that was rattling apart, pulled it off and JB'ed the baby and she has been solid as a rock to this day
best failed..... i was trying to make a jockey shift outta an old WWWII pinnaple grenade and didn't have a die big enough so i figured if i just jammed a **** load of JB in there and then jammed it on the shifter rod i would be good to go......not so much lol
BEST-- Sealed an external crack in a Chevy block, as far as I know it is still holding today.
WORST-- I attempted to repair a cracked exhaust manifold on an old ford truck. I guess it was too much heat there.
Plastic fuel tank on a dirt bike in the middle of Baja. Held for years until sold. Never had a bad one. Took the emblem off my backrest and JB'd two small bolts to it and bolted it to my backrest bag. Still holding after two years.
