any mechanics in rockland county ny?*NEED HELP*
Hey, i really some advise what to do. if anybody lives near rockland county ny.please help.i dont need you to do the work but i need you to listen to the bike to help. i will tow to you if you want but can somebody please help. i new to this stuff and need a professial opinion.
thanks i have cold beers food and good music if needed please help |
RE: any mechanics in rockland county ny?*NEED HELP*
Maybe if you describe the problem someone here can tell you what's up?
i just replaced the head gaskets on my 02 sporty. i there is a knocking(pinging) sound coming from the rockers. i m not sure if it the push rod,valves or the rocker arms itself.i would somebody to listen to it to tell if it bad or just keep riding. i tighten the head bolts alittle tighter then before(i tightened them to the gasket instuctions not the fm torque and turn method)i tightened it to 45ft pounds.i think i install every thing correct because this my 3rd time doing this. i had alittle to much oil at first. drain some and it got a little better,but i v read that its a sporty and the valve make some noise some time.i didnt change the valves or the seats. just need some advise.
thanks |
Give Stu a call, his shop is located at 11 Washington Avenue in Suffern. 845-357-5678.
© 2024 MH Sub I, LLC dba Internet Brands
