Catalytic Converter Pic - 2010 Dyna Muffler
drilling, punching out, removing cats on cars with an o2 sensor after the converter will set off the check engine light on cars and trucks. The down stream o2 sensor is only there to monitor if the cat is working or not. I do not know if Harley has one after the cat or not. Never thought to look.
Not Yet!
EPA's gonna get ya!
Don't know about the rest of it, but the Dyna line just started getting muffler cats (outside of ca), and there ain't no cat in the headers. It would make no sense to have a cat in one muffler and not the other (there's a cat in each of my stock mufflers)...with a cat in only one muffler the back pressure imbalance would be rather extreme...probably more than the little header crossover could compensate for.
Crusty, you are incorrect sir. I have pulled exhaust systems on every model except V-rods, 06 - 08, and the mufflrer to the front cylinder has had a cat. It is even stamped on the back side of the muffler "CATYLIST". Have not looked at 2010s, so it may have cats in both mufflers. The 2010 tourers have the cat in the head pipe.
semper fi
check 6
Bwana
semper fi
check 6
Bwana
semper fi
check 6
Bwana
Were you working on California models? I'm not in California.
Semper Fi,
krusty
Crusty
All bikes were in the southeast; FL, MS, TN, AL. Don't believe everything the dealer mech tells you, cause I can guarandamntee you that the 06, 07, and 08s had one cat in the front cyl muffler and the CA bikes were this way starting in I believe 2004. If your 2010 Dyna has CATS in both mufflers, than I assume that all 2010s have the two cats and that the tourers have a CAT in both headpipes.
Bwana
Bwana
Cats
Cali & CVO have had em for a while, lower state odd years in one muffler different models!
None on state 09 bikes, they had a narrow band heated 02 sensor in the exhaust stream from each piston, EPA CAM and Lean AFR to help meet the requirements without the use of a CAT.
2010 the Emissions Standards got real strict, all of the above plus the addition of catalytic converters in the headpipe all the baggers and in the mufflers for every other model.
All the 2010 Metrics have the cats also! I had a thread that caused a lot of controversy "Build a Better Mouse Trap" alluding to the fact the industry needed to join forces and find some other way than a Catalytic Converter to meet the new 2010 EPA emissions standard's. I said I would revist the thread after the summer of 2010 when all the big heavies went through the hot months of July and August!
More and more threads about the Cats and no need to get into a tizzy just yet! I don't believe a Cat belongs an Air Cooled engine! They may as some of the metrics water cooled work on certain typed of water cooled engines but not the Harley!
A 100 year old design that depends on its signature sound, "a free flowing exhaust" as one of it's main selling points! Might be able to water cool the heads but the bottom end is where the sound comes from! Harley in particular needs to do some R&D towards coming up with another way of meeting the emissions standards.
We all are aware of the Harley Tax, we change that exhaust out anyway and make other mods, hardly anyone is satisfied with a harley right out of the box. Most of the stuff we do for performance will help cool one down and make it sound more like a Harley!
Just saying, it ain't just Cali and CVO bikes anymore, it is every 2010 model and beyond. You can't skin em all without drawing the evil eye of the EPA. We lose our aftermarket people and we are screwed!
you have either 1,2, or 4 o2 sensors.
If you have one, it is before the cat always.
If you have a twin cyl with 2 sensors they are always before the cat.
If you have 4 o2s, two are before cat for fuel mixture metering, two are after for catalyst monitors.....thats what I was getting at.
ALL OBD 2 and later systems are 4 sensor systems. I dont know what Harley is using because I never looked. But I bet they are a step behind cars and trucks and only using 2 sensors for fuel metering only.
The day they use 4 will be the near death of Harley because then the only way you can lose the cat is to use an o2 eliminators, or reprogram the computer to not look at the secondary o2 sensors. So if the cats are in the mufflers, you would be stuck with stock mufflers with cats, or aftermarket pipes with cats....the old harley sound will be lost unless you are a tech geek and can reprogram the computer, or fool the sensor readings.
