Engine tick
Old Apr 11, 2010 | 04:14 PM
eric91379's Avatar
eric91379
Cool Engine tick
I have an '03 FXSTI with about 15K miles on it. I have a ticking sound on the right side. It is intermittent and changes with RPM. The motor fairly stock with just bolt on stuff. The ticking started after the bike was shipped from Maine to Hawaii when I transferred duty stations. It is my only vehicle and dot have time (or money) to take it to the shop. Any ideas?
Old Apr 11, 2010 | 06:24 PM
harleydavis's Avatar
harleydavis
You are probably hearing valve train noise, which is common for Harley's with hydraulic lifters, push rods, and rocker arms. However, if it starts getting a lot louder you could have a collapsed lifter. Just keep monitoring it, but if you are really concerned take to a dealer or indy and have a mechanic come out into the parking lot to listen to it.
Old Apr 11, 2010 | 06:32 PM
soft 02's Avatar
soft 02
do you have a bell down their or maby its a rattling gas cap or those pesky criticle fasteners.
Old Apr 11, 2010 | 06:48 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Check your heat shield for debris in between the shield and header pipes. I've heard if a bike is shipped in gear its possible the motion of the bike will pump some oil out of the lifters via the valve train. Then again the HD valve train is exactly super quiet.
Old Apr 11, 2010 | 10:35 PM
oct1949's Avatar
oct1949
check for a bolt or rock in tires... had a rock in the tire one time that made a ticking noise..
Old Apr 11, 2010 | 11:07 PM
DinoVelvet's Avatar
DinoVelvet
mine does the same thing has about 30K on it...
Old Apr 12, 2010 | 12:20 AM
hatchetman's Avatar
hatchetman
pour some mmo in it & see if it settles down. You might think about an oil change as preventative maintenance!
Tharry91
Engine Mechanical Topics
23
Oct 4, 2018 01:45 PM
lmz5150
EVO
15
Sep 9, 2018 09:13 PM
Robtarra39
May 1, 2016 11:37 AM
Fierofly
Jan 20, 2013 04:04 PM
mhud
Exhaust System Topics
May 28, 2009 04:09 PM
