Harley Genuine Fuel Additive?
Old 04-26-2010, 06:15 PM
zjhanson's Avatar
zjhanson
zjhanson is offline
6th Gear
Default Harley Genuine Fuel Additive?
Hey guys I've seen this at the harley shops for a long time now and never put much thought into it but after reading around abit I've heard several guys say good things about it. It has Duralt in it which is supposed to be good at extending gas mileage or something, it also says it can raise octane of gasoline by 3 or 4 points so I don't know if this means that it would be like 87.3 octane or what mabye does it mean that it will turn 87 into 91 rating?
Currently I always use 92 octane gasoline but do any of you guys use this additive with regular 87 gas to raise the rating or should it be used with the already high 92 octane gas?
I've been using sta-bil for a number of years now and just recently I began using lucas fuel injector cleaner in my truck with excellent results also in the bike just now curious about the harley version. thanks for any advice or input
P.S. Is there anything that Harley-Gloss dosen't do well, I swear this is the most amazing general purpose cleaner that i've ever used even works wonders on my lexan windshield. H-D deserves some respect for making such a great product!
Old 04-26-2010, 06:31 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
I use Techron or redline SI-1 fuel systems cleaner.
Old 04-26-2010, 09:42 PM
big cahuna's Avatar
big cahuna
big cahuna is offline
It don't make much sense to use regular gas, then add an additive to raise the octane rating when you could just run high test. It would be easier to get and you wouldn't have to buy, then add the stuff. Also I've heard to raise octane ratings 5 points, you need alot of additive.,,
Old 04-26-2010, 09:47 PM
otlawpan's Avatar
otlawpan
otlawpan is offline
Ill make this short. Dont waste your money with additives or octane boosters, just use good premium gas and be done with it. If you want higher octane gas buy racing gas and mix with regular or premium, octane boosters dont do danything but empty your pocketbook and peel your paint.
Old 04-26-2010, 09:48 PM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
I keep a vial of the stuff for the times when traveling when you can't find premium gas.
I've used it a couple of times, and it seems to work at preventing knock when forced to run low octane gas.
In my T150 Triumph, (requiring 97 octane) I used to add something called Octane 106 Boost. That crap coated the cylinders and plugs with an orange deposit, but it also worked.
Old 04-26-2010, 09:50 PM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
Always use the Premo fuel & add a bit of Seafoam for freshness. Hasn't failed me yet...
Old 04-26-2010, 09:52 PM
cHarley's Avatar
cHarley
cHarley is offline
It means it will raise 87 octane to 87.3. A point in this case is 1/10.
Stay with higher octane, Brand Name gas (they all have cleaner additives), and forget the snake oil.
Old 04-26-2010, 09:59 PM
Mr. Lucky's Avatar
Mr. Lucky
Mr. Lucky is offline
You were right the first time (e.g., takes 87 to 87.3). That's too little to make any difference if you end up with low octane in the tank, and no benefit with normal fuel in a stock motor.
Old 04-26-2010, 11:09 PM
oct1949's Avatar
oct1949
oct1949 is offline
Seems weird that my manual say's not to add anything then go to a dealership and they sell stuff to do it..
Old 04-27-2010, 05:27 AM
Uncle Scrooge's Avatar
Uncle Scrooge
Uncle Scrooge is offline
I tried one bottle of the Harley stuff. Couldn't see it made any difference.
Quick Reply: Harley Genuine Fuel Additive?
