2010 Super Glide - 3K and the rear hub is howling like a banshee
could there be to much slop in the bearings themselves between the bearign races and the bearign surface? never seen bearigns go out that fast on anything besides my 4x4 ands only because of what i do to it in the bush.
if the deflection is correct, try lubing the sides of the belt with paraffin wax. Every so often I will notice a slight chirp or whine from my belt. Hit it with a quick dose of wax and am good to go.
I'll give your parafin suggestion a try tomorrow. Maybe I've unfairly maligned the noble beast. I do love the bike, and how she handles.
Received 20,863 Likes
You know, I heard Honda makes a good parafin, Or was it Yamaha???? j/k I hope it works for you. That would beat a trip to the dealer.
I even got her (the bike, not the OL) up to speed in a big empty parking lot, put her in neutral, and switched off the engine...and it's definitely coming from the rear hub/pulley area.
I'm new to Harley's, but not new to motorcycles....I guess I'm just gonna have to learn their little tricks. I'm well acqainted with motorcycle brake problems (clunking, pads not retracting....but this is a new one on me....maybe because this is the first bike I've ever had with a belt....it's all been shaft drives and chains for me.
Next you're gonna be telling me that it's important to use belt dressing derived from the hide of old metric riders to quiet my belt drive!
It's only lightly touching the left side of the pulley, but I'll realign the wheel (and retension the belt). Very easy to do....everything is right out there on a SG. Alignment pin holes on the swing arm are easily accessible.
Rear bearing failed in my '08 at 14k.
I felt it happening through my pegs (a grinding sensation sometimes) plus the ocassional 'chirp'.
When the indy pulled the rear tire off the belt side bearing was in pieces.....
