another 6 speed harley transmission failure
#501
I have a 2006 Wide Glide that I bought in January 2014- the first year for the 6 speed in the Dynas.
The bike had 14k miles on it. The rear main bearing failed. HD replaced it and I was only charged a $100 admin fee.
I can't imagine another company that would pay to replace a transmission on an 8 year old bike.
#502
#503
Bearing failure
Just got home last night from Rolling Thunder in D.C. 750 mile ride, anyway couple hundred miles into the ride the tranny started howling. Didn't affect the performance but I did have to turn the radio up! Once I pulled into the garage, the bike dropped all the tranny fluid (Belray). 71K on an 07 FLHTC. Changed the tranny and primary fluid with every oil change (4 thousand miles). Tension on the belt is just a hair loose. I ride the bike hard, I take care of it but I do ride fast and hard. Tranny has always made noise. No matter what fluid I run in it, it always sounded like my Ma's old junk mixer. Now it could be a factory defect but at 71K, I think it would have failed earlier. BTW, I read a lot of postings but it has been 3 years since my last post. How is everyone?
#504
Dealer ordered all new bearings and replaced them.
They said make sure you use a belt deflection gauge and check your drive belt all the time.
#506
2007 6 speed counter shaft
Trans noise started 500 miles ago. Last ride, progressively loader 2nd upto 5th, no noise in 6th. Extensive experience with Muncie 4 Trans in the day! To this point have replaced 2 output shaft bearings, and compensator. Will tear down tomorrow. Total miles 60k. Expect to find failure of needle bearing on counter shaft. Metal on drain plug, side door bearings look fine. More in come!
#507
#508
#509
Agree 100%. Some guys just don't have that many miles on their bikes. Back in 07 when my comp failed and I called them a piece of crap everyone thought I was nuts. Their time will come.
#510
transmission noise 2007 flhtcu suspect counter shaft needle bearing.
BEARING that failured was the Main drive gear double ball bearing. Outside half saw toast possibly due road salt contamination! Gear collar under that half was rusty. Inside bearing half was fine. Noise in 5th but not in 6th was possibly due to side torque from counter shaft, where as in 6th the primary chain and drive belt tensions cancelled each other out.
