Stupid question...
Old Sep 12, 2010 | 07:23 PM
smithr's Avatar
smithr
Default Stupid question...
If you drop a o-ring (used on drain plug) in the oil reservoir on a '10 Ultra Limited, will it go to bottom and cause a problem?..can't see down in there, I hope that's not where it went. Any suggestions?
Old Sep 12, 2010 | 07:27 PM
Mike T's Avatar
Mike T
I'm thinking no.But then again,man, how'd you do that!
Old Sep 12, 2010 | 07:28 PM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
I don't know about it being a stupid question, but dropping the o-ring from the drain plug into the oil tank...that would be pretty stupid...
Old Sep 12, 2010 | 07:35 PM
Steve On 3's Avatar
Steve On 3
I'd think Murphy's law would come into effect and that o ring would turn sideways and wedge somewhere and cut off your oil flow. How hard is it to take the oil pan off and remove the o ring and be safe? Much easier than an engine rebuild
Old Sep 13, 2010 | 07:38 AM
carlgrover's Avatar
carlgrover
Yes. Talk to Murphy about what could happen.
Old Sep 13, 2010 | 10:07 AM
frog13's Avatar
frog13
I'm with these guys, it would freak me out. That rubber ring is small and will move about, eventually it will end up somewhere and that somewhere may not be good. Now, where is that rubber ring magnet?
Old Sep 13, 2010 | 10:18 AM
gascap13's Avatar
gascap13
Have you tried using a compressor hose around all of the external nooks and cranny's that the o-ring could be hiding? As far as the "rubber ring magnet" goes, try using a rubber glove and some plastic tubing on the end of your shop-vac hose and insert it into the crank case. Fish around and pull it out until you have caught the o-ring.
Old Sep 13, 2010 | 10:24 AM
CroK's Avatar
CroK
Dropping stuff into the oil fill hole seems to be a growing trend around here...
If you are not checking oil level, or filling the oil tank/pan, KEEP THE DIPSTICK IN THE HOLE! Now, that's thinkin with yer dipstick, jimmy!
Old Sep 13, 2010 | 10:25 AM
XL50#674's Avatar
XL50#674
This is a good idea first. Why in the hell would oyu have your drian plug by the oil inlet? Remove the drain plug and lay it on the floor after whiping it off til it's time to reinstall it.
smokeygold
Oil Archive (no new posts)
11
Oct 18, 2016 05:15 AM
harleybob
Apr 24, 2012 10:12 PM
harleydom55
Aug 11, 2008 05:09 PM
heg108
Aug 27, 2007 04:03 PM
Firefox
Aug 30, 2005 01:01 PM
