How to keep the paint stuck to my new shift knob?
I got a new shift knob and the wife is painting it for me. Once it is painted I was thinking of using Krylon acrylic clear coat to seal it. I am not sure if this is going to be enough to keep the acrylic paint underneath from flaking off eventually with the amount of use this thing gets. Can I get it powder coated clear or something? No pics of teh shifter until the paint job is complete. It will probably be a few days although she is working on it now.
Drew |
Originally Posted by DR. V-TWIN
(Post 7569172)
Drew The big question is....What type of paint is your wife painting it with? Compatibility between what she used and urethane clear is another concern. Urethane is pretty aggressive and can lift alkyds and acrylics... sign painters paint and paint used to make pin stripes should be compatible with urethane's. Hope this helps.... Any coating related questions feel free to shoot me a message, I've been in the field for 28 years and do not mind offering my 2 cents. |
(Post 7569172)
Drew I'm curious to know how it turns out. |
My first thought is clear epoxy. It's the coating used on lotsa bars (the place you sit and drink) when they want to seal thing into the surface.
This might sound weird, but I coated a wooden handle for an outdoor fireplace poker with Gorilla Glue. It dries clear and shiny. That thing stays outside 365 days a year, and still has a nice coating on it. Nothing penetrates that stuff.
You may want to try it on a practice piece first. |
Thanks guys. the paint job is done, waiting for my phone to update to get a pic. I can always have it repainted. I guess the one shot sounds like the best idea. We'll see how this wears. I avhe to drill and tap it still too. I probably should have drilled and tapped it first too. It is all a learning experience for me.
Drew |
if it were mine I would dip it in clear epoxy.
Try some automotive clear polyurethane. Two or 3 coats of that will should last awhile.
Originally Posted by RHPAW
(Post 7569811)
Since I used acrylic paint, which is water based I have to be careful what I use to coat it or it will crack. I'm going to try 10 coats of the Krylon acrylic sealer. It needs another day or two to completely dry. I just drilled it. Small bit, bigger bit, bigger bit. Easy as pie.
Drew |
© 2024 MH Sub I, LLC dba Internet Brands
