Hey Bob... given the list of mods on my bike, where would u recommend the jetting to be? The more I read the more I think my intermediate jetting may be rich.
I'd go with a .0295 or a .031....Also check the mixture screw adjustment..The standard setting is 1.5 turns out after screwing in the mixture screw all the way. Start out with the .0295 if you need to change the Intermediate Jet.
You also need to shut off the accelerator pump when dialing in the carb!
i am wondering if you didnt develop an intake leak on your rear cyl. and then adjusted the carb. making up for that leak on the rear cyl. but dumping fuel to the front...thus the fouled front plug------somthing free to check.
while in your possession was this bike running good? or a new bike for you or loaned out?
what does the spark look like?
