heated dipstick?
Old 11-22-2006, 11:40 PM
Dancemax's Avatar
Dancemax
Dancemax is offline
Default heated dipstick?
Any one know if I could use a heated dipstick in winter to keep my softail oil warm. I think automotive stores sell them. HD hot dip stick would be a hot seller.
Old 11-22-2006, 11:45 PM
The HalfBreed's Avatar
The HalfBreed
The HalfBreed is offline
Default RE: heated dipstick?
Do you keep your bike outside all winter ? I don't think it's necessary, unless you live in Alaska, then a PAN heater would be better. The Temp of those dipstick heaters can get quite high, and 'burn' your oil somewhat, but, the transference of heat, via the oil would eliminate most of those effects. Keeping it on a Battery Tender may be a better option, IMO.
What state are you located ? If you use Synthetic oil (Full Syn), it should not be an issue.
Old 11-22-2006, 11:55 PM
Dancemax's Avatar
Dancemax
Dancemax is offline
i keep it in my garage, not heated course. I am in Detroit, Michigan mostly in 30's, occasionally way below freezing.
i justthought that warm oil might be easier on a very cold engine. I do use a battery tender.
Old 11-23-2006, 12:36 AM
KeithB's Avatar
KeithB
KeithB is offline
Big Kahuna HDF Member
might keep moisture out? or would it cause more? not sure
Old 11-23-2006, 04:47 AM
E DOGG's Avatar
E DOGG
E DOGG is offline
I'm sorry. I keep thinking of a Heated Dipstick into a Soft TAIL !!?!
Old 11-23-2006, 07:35 AM
Ram's Avatar
Ram
Ram is offline
ORIGINAL: Dancemax
Do you plan on starting it and riding it during the winter?
If so you will keep the oil warm enough just by having a small heater out in the garage and turn it on facing the engine/tranny a short time before start up. That will help it warm up a tad bit and maybe make it just a little bit easier to start.
As was stated above, a tank heater on the outside of the case, or just heat the entire garage to 45-50*.
I don't hardly think its necessary to heat the oil.
Just besure that your garage is not some kind of a moisture trap and allowing all kinds of condensation to build up all the time. A humitity meter from your local pet store for a few bucks will let you know whats happing.
Old 11-23-2006, 09:49 AM
flakdog's Avatar
flakdog
flakdog is offline
ORIGINAL: Nu B StreetGlider
Great minds think alike! Same here LOL
Old 11-23-2006, 11:35 AM
DenimStreet's Avatar
DenimStreet
DenimStreet is offline
A heated dipstick? Isn't that what you call an angry guy on a Honda?
Old 11-23-2006, 12:13 PM
DoCPooF's Avatar
DoCPooF
DoCPooF is offline
Do you play on riding it?
If not don't worry about it. I think the scoot won't break if it gets cold. I highly doubt it will get cold enough in your garage to freeze the oil.
Old 11-23-2006, 12:42 PM
Dancemax's Avatar
Dancemax
Dancemax is offline
The reason I brought it up was that we used to put a light bulb under the cowling of our flying club cessna 150 and allother airplanes. This was tremendous help on starting a cold engine. They say that the biggest strain on an engine is the first few strokes on starting when the lube is too thick and not enough. So it does make sense to warm the engine with external heat in below freezing temperatures. Last nite I put a 75 watt handy light bulb next to oil tank. Put a blanket on the bike and this morning iit feels good. It is not as cold here in michigan today. I am gaonn ride and ride........talking about humour, yes....there are some real funny guys on the forum; are't they?
Quick Reply: heated dipstick?
