no low fuel light
Old Apr 14, 2012 | 11:04 AM
Nor Cal Mafia's Avatar
Nor Cal Mafia
Ill have to check..Havent done an odomoter/mileage check yet but the needle is buried on E and tank looks/ sounds dry.
Old Apr 14, 2012 | 02:18 PM
DannyZ71's Avatar
DannyZ71
My light comes on when I have 42 miles showing on the range gauge. But the gas gauge is already showing empty by then. I trust the range gauge more than the gas gauge. In fact, I wish they would do away with the gas gauge and put a regular gas cap there like they used to.
Old Apr 14, 2012 | 02:46 PM
piasspj's Avatar
piasspj
How many gallons does it take to fill up?
Old Apr 14, 2012 | 02:54 PM
petom's Avatar
petom
Originally Posted by jayc67
One of the first thing that pilots and motorcycle riders should do is simply tape over the gas gauge, it will only lead to trouble in the long run.
What he said.
Old Apr 14, 2012 | 10:52 PM
marines267's Avatar
marines267
2012 streetglide gas gauge is working fine but low fuel light doesnt come on?Talk about it...
When my gauge is on empty the light is not on until I go another 40 miles than it will be on and than I only have 1 gallon left in the tank. But after running my tank down to empty every time for more than a year I learned that you do not want to run it that low because the fuel pump is in the tank and the gas helps keep the fuel pump cool and if you run it down to empty your fuel pump might get hot like mine did and than crack
Old Apr 15, 2012 | 12:33 AM
dickey's Avatar
dickey
ON my RKC, the guage is pretty accurate, but when that light comes on I gotta get gas like NOW, 'cause I have about a mile before she's OUT! happened to me a couple months ago; fortunately right in front of a gas station.
Old Apr 15, 2012 | 12:48 AM
lo-rider's Avatar
lo-rider
OP--Forget about fuel gauges and lights. You should be using your trip odometer to determine when to refuel. It is helpful to keep a fuel log.
Old Apr 16, 2012 | 06:28 AM
oct1949's Avatar
oct1949
5yrs and 36K and I've never had any problems with either the gas gauge or low light, the light has always come on between .9 to 1.1 gal left in the tank and that's usually between 165 to 190 miles after filling her up, depending on where I am riding.
Average putting around the light comes on around 175.
J.R. White
May 7, 2024 01:19 PM
bberck
Mar 10, 2010 02:57 PM
trackadaptor
Jan 7, 2010 11:48 AM
SportsterPapa
Sep 12, 2009 02:30 PM
EV
Exhaust System Topics
Jun 30, 2008 11:59 PM
