How to lift a softail?
I just picked up a 1500 lb bike lift from Northern Tool and if I center it under the Fatboy it hits on the shocks. What do you guys do? Thanks!
Put a piece of scrap 2x under your jiffy stand. It will give you enough room to slide the lift under.
Or just rock your bike a bit to the side opposite the jack. Mine did that too and all I had to do was put my hip against it to lift it about 1/2". Or run your front wheel up on a 1"X4" piece of lumber.
Roll the bike so the rear wheel rests on a piece of flat wide wood of the height you need to get the lift under. It's how you jack up a slammed car. ;)
Originally Posted by arcticharleyman
(Post 10232763)
I cut a couple pieces of 1"X4" and laid them on my jack just under the frame tubes, running front to back, not from side to side.
Originally Posted by Joker's back
(Post 10232815)
Edit: I just read your last post. I lift both my bikes often, and have never damaged the shocks. |
You are not going to hurt the shocks by lifting the bike. Been doing it with no aids on the wifes 2006 Deluxe since we got it new. NEVER a problem of any kind. Its not as if you are slamming the shock with a sledge hammer...you are just lifting on it, and it will move enough to lift with no issues.
Hell, I have even left the bike on the jack over the winter, and still had no issues...Its a bike, not a china doll. Don't worry so much, and enjoy the bike. |
Keep jacking it up the other tire will lift eventually
(Post 10232887)
© 2024 MH Sub I, LLC dba Internet Brands
