I called them and they are out of stock for at least 3 weeks. There may be other dealers that have one in stock but damned if I found one yet. Now I am looking at the Titan lift. That sucker raises 45" high, 1500lbs and comes with the extensions. |
Paid $750.00 in 1999 for mine, kitted out the same way, 1500lbs
Still have it |
Originally Posted by BigGelvis
(Post 10561493)
I'll be damn! The dude doesn't even know what he has. I went and looked at it and while it is in decent shape, it is a 13 year old 1000lb Handy.
I have no idea how he thought it was a 1500lb. And he is stuck on $750. I told him I would give $450 just because that would be a good deal I think. But I really need and want a 1500lb capacity lift! Anyway, thanks for the help and consider this thread DEAD! |
Originally Posted by xwhyz1959
(Post 10562097)
Why do you "need" a #1500?? I have a Handy #1000 that lifts my 08 Ultra just fine.
The 1500lb lifts go from 38" to 45". I am 6'2" and like to work standing. I want higher lift and also the extra capacity. They rate them @ 1000lb for a reason. And my bike is pushing that limit. You can max your lift out all you want, it will probably never fail but with a 1500lb, I believe you will get beefier construction, larger lift and greater lifting height. That's why. |
(Post 10562127)
Main reason is lift. There is no 1000lb lift that goes higher than 33".
Does anyone have any experience with this Black Widow lift? Thanks
http://www.ebay.com/itm/310500018134...84.m1423.l2649 |
Originally Posted by kspencer2
(Post 10564090)
(Post 10564628)
Same one Snap-on sells around $3000 plus , would love to have one but keep in mind it's BIG takes up a lot of floor space . Be aware it is imported , the low end Black Widow lifts are the same as Harbor frieght's .
Originally Posted by firefighter616
(Post 10564967)
YEAH, and how do you know all that, Hero :icon_nic:
Thanks Twizted, I have a large garage and it would be used for personal use. I'm still shopping but this one caught my eye. I'm also looking at the Handy but don't know if I need to spend that much for home use. All advice is appreciated. thanks again
© 2024 MH Sub I, LLC dba Internet Brands
