Gauge Face App.
gives you speed,tach,engine temp,signals,current gear & music. requires a gauge face hardware adapter.
www.gaugeface.com/
reviews are good, seems like it would work best on older bikes that dont display this info. or for the guys and gals abroad that can change from MPH to kph.
please keep us posted if you buy it.
www.gaugeface.com/
I seriously considered getting a GaugeFace for my Road King. However, the two biggest drawbacks were seeing my iPhone in full sunlight and having to remove and reinstall my iPhone for extended stops where I'm away from my bike.
Recently I did a stage 1 upgrade and used the Power Vision tuner. It turns out that the PV allows you to display all sorts of engine and riding data. I programmed a screen where I see six digital values on the PV screen (speed, tach, temp, current gear, battery voltage, and trip odometer). It is mounted above my handlebars using a RAM mount. I pretty much leave it installed, but if I had to remove it during a stop, it would take only a few seconds. Anymore I use the PV instruments and don't even look at the speedo on my tank. Even in full sunlight I can see the numbers against the black background. They do make a sun visor for the PV which I might try out.
