pipes dragging
Old Dec 27, 2012 | 07:13 AM
primostoy's Avatar
primostoy
Default pipes dragging
Ok, got my new Paugcho upswept pipes installed, took it for a ride yesterday and even on a moderate turn to the right the lower pipe is dragging on the ground, now I have scratches on that one pipe. I know too many times like this and there will be a hole there, anyone else have this problem and how did u solve it? Could be any exhaust, doesn't have to be Paugcho...
Old Dec 27, 2012 | 07:27 AM
mjrfd99's Avatar
mjrfd99
I've welded grind plates on the shovel every time I wear the pipe [Pythons] thru. Harleys sit low - your gonna scrape if you get even a little agressve in turns.
The stock Heritage scrapes all the time, can't even imagine lowering one of them at all.
Low bikes scrape the ground like randys big fat butt. Can't change physics.
Right hand turns are a light show on this one:
Last edited by mjrfd99; Dec 27, 2012 at 07:29 AM. Reason: I make big twins look like sportys LO f'in L
Old Dec 28, 2012 | 02:38 AM
Tampakingpin's Avatar
Tampakingpin
Man, I hate grinding into a new pipe
Old Dec 28, 2012 | 05:00 AM
Campy Roadie's Avatar
Campy Roadie
Is your bike lowered at all? If it is, you may need to consider using stock height suspension. Or live with it. Keep in mind, dragging hard parts, if done with enough lean angle can lever the rear wheel out from under the bike for a low side crash.
Old Mar 18, 2013 | 07:55 AM
kraznos's Avatar
kraznos
I made these myself for $45. I don't mind a beat up look. They don't scrape.
Old Mar 18, 2013 | 08:37 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
I can't imagine leaning into a turn enough to drag a pipe...or anything else. I guess I'm just too worried it'll go out from under me.
Old Mar 18, 2013 | 08:41 AM
Chubby's Avatar
Chubby
Good job! Skid plates are the next best thing.
I drag my floor boards before I drag the pipes unless I'm going over a bump.
Old Mar 18, 2013 | 01:41 PM
mswing1234's Avatar
mswing1234
I'll be half way through my board and laying on the ground before I drag mine.
Guess that was an afterthought?????
Old Mar 18, 2013 | 06:47 PM
streeteagle's Avatar
streeteagle
One thing about my "shotguns" I would have to be at an extreme lean angle to drag mine. When my pegs drag I know I'm getting close to my limit.
hdrider98ci
May 12, 2013 10:45 PM
toastman
May 28, 2012 06:44 AM
newdep332
Dec 8, 2009 09:53 PM
Springer95
Jun 20, 2009 06:50 AM
FlatBlackBob
Jun 13, 2006 11:52 AM
