Pulstar Spark plugs are they really worth it?
Stick with OEM or equivalent. I got suckered in to the Pulstar plugs. Drop in MPG. It did start better when cold but thats it. Gave them to a friend and he didnt like them either.
In a word 'no'
It has been proven many times over that no spark plug can improve performance or mileage. If you see a performance or mileage gain by installing a different spark plug, it is most likely because you 'accidentally' indexed it perfectly.
I know a lot of people think Plugs are Plugs, but I don't agree. You can clearly notice a difference in running NGK Iridium. As soon as you start the bike you can hear, feel & see the difference even when idling. In fact my idle increased on both bikes when I installed them. My Evo had a mid-range flat spot that's no longer there since the NGK plugs were installed. And I've seen mileage increase on both bikes as well. They're only about $15 per pair on eBay. For that price they're certainly worth a shot. They're all I'll run anymore, well worth the few extra bucks IMO.
Here's more info on these plugs if anybodys interested:
If you know about precision and performance for your motorcycle and ATV, then you know about NGK spark plugs. NGK/NTK technical ceramics is the leading manufacturer of automotive, ATV and motorcycle spark plugs - NGK plugs are OEM equipment in more vehicle models than any other brand.
Designed to US, European and Japanese OEM engine specifications, NGK’s Iridium series power-sport plugs deliver enhanced ignition efficiency and superior engine performance across MX/off-road, highway, street-race and track applications.
NGK Laser Iridium and Iridium IX features:
•Precision Laser-welded Iridium center electrodes – 6X harder than platinum
•Precision alumina ceramic insulators
•Corrosion-resistant shell with triple high pressure gas seals
•Screw or snap-on electrical connectors
•Pre-installed metal compression gaskets
•Copper-core electrode cooling
•Application specific heat-range design
•OEM approved – Designed for high performance engines
Benefits of NGK Iridium Series Spark Plugs:
•Improved cold-starting performance
•Smooth firing at high or low engine RPM
•Reduced electrode erosion and long service life
•Enhanced ignition efficiency and fuel economy
•Superior anti-fouling characteristics
•Reduced hot-spark firing voltage requirements
•Maximum engine horsepower and torque
•Superior throttle-response, acceleration and WOT performance
Compatible with aftermarket ECU/ECM engine controllers and AFR monitors (Dynojet Power Commander III, WEGO II, AEM, Drivven, PLX, PowerDEX. Original equipment in Aprilla, BMW, Cagiva, Ducati, Honda, Husqvarna, Indian, Kawasaki, KTM, Moto Guzzi, Norton, Suzuki, Triumph, Victory and Yamaha. Equivalent/upgrade replacement for AC Delco, Autolite, Bosch, Champion, Denso and Motocraft plugs.
