Torque specs for inner primary? Thanks!
Left my manual at home. Anyone have the torque specs for the 5 inner bolts and outer primary cover. Doing my 3rd compensator and replacing the auto adjuster with the Baker unit! Thanks a bunch!
2007 FXST.
2007 FXST.
Received 20,876 Likes
Well, it looks like the primary drive cover is gonna be 80-110 in. lb....... But that's for a 2002 1200C.
From my '010 Dyna manual :
inner primary sealing bolts (2 behind compensator, 3 behind clutch pack) torque is 25-27 ft-lbs;
compensator bolt final torque is 140 ft-lbs;
chain tensioner fasteners torque is 21-24 ft-lbs;
primary cover screws torque is 108-120 in-lbs.
Note: the Softail motor is different than the Dyna's, so use the above values at your own discretion.
johnharley
06-23-2012 05:55 AM
racezilla500
05-05-2006 07:50 AM
