Ringing Sound
Old Mar 27, 2007 | 07:37 PM
bosnmate's Avatar
bosnmate
Default Ringing Sound
Lately it has been in the 80's here in the Atlanta area. On the hot days when the bike has been riden a lot. I hear a tuning fork type constant ring that is coming from the rear of the motorcycle.
Any ideas what this is????
Old Mar 27, 2007 | 07:45 PM
mistermooster's Avatar
mistermooster
Default RE: Ringing Sound
You should've tuned your bike with a SERT/PCIII/FuelPak.... not a fork.
Remove tuning fork immediately, the sound will disappear.
Sorry. Couldn't resist.
Old Mar 27, 2007 | 08:10 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Are you wearing ear plugs? That ringing might not be the bike.
Old Mar 27, 2007 | 08:57 PM
firemankrug's Avatar
firemankrug
ORIGINAL: mistermooster
[sm=funnypostabove.gif]
Old Mar 27, 2007 | 09:27 PM
EasternSP's Avatar
EasternSP
Could be your rear brake singing. I've been struggling with that on my RG for the past few weeks. Used De-squeak and it works for a while but the squeal comes back. I think the next thing I will try is grinding the leading edge of the brake pad. I'm not sure if this is covered under the warranty. I'll have to give the dealer a call before I start grinding.
Old Mar 27, 2007 | 09:50 PM
bay13's Avatar
bay13
Going fast, slow? Does it go away if you gently tap the rear brake? By weaving/leaning left and right does the sound change?
Old Mar 28, 2007 | 01:32 AM
bosnmate's Avatar
bosnmate
ORIGINAL: bay13
Going fast or slow it does it. Doesn't stop when you tap the brakes. It only does it when it is hot outside and yes the sound changes while leaning either direction.
Old Mar 28, 2007 | 10:23 AM
mtnlvr's Avatar
mtnlvr
Might be a good timeto do a bolt check.
Old Mar 28, 2007 | 10:41 AM
Gerard's Avatar
Gerard
Same problem here but I only hear it when I'm next to a metal guard rail. I guess the sound is reflecting back at me and amplifies the ringing. I had this once before and went away when I installed different baffles. Just a guess but it could be your baffles may need to be tightened up. Not sure what the ambient temperature has do do with it but itwould effect the thermal expansion characteristics of the pipes and baffles.
Old Mar 28, 2007 | 10:44 AM
whaap's Avatar
whaap
I've had the same thing, especially so in hot, hot weather. The best I can figure out is its a resonance caused by the side of the belt rubbing against the pulley on the wheel. My Sportster is a right side drive and I notice the sound comes mostly from the right side. You have a left side drive. Do you notice it more on the left?
