Help with ape hangers, concerned
I just had my 14 inch flyin carlini ape hangers put on and im a little concerned. The bars move forward and backward...sloppy like. Is that normal?
I'm guessing you had the install done??
Ask em what damper kit and bushings they used. It's ok to have a tiny bit of play, but not sloppy loose. You've got a bit more leverage with apes, so they will have more give, but again, shouldn't be sloppy.... |
I just installed 14" PY bars on my bike. There was some play with the stock bushings. I installed polyurethane bushings and most of the play is gone. I get the bar shake at stop signs, but I kind of dig that! When I say "play", I mean bar flexing back and forth.
Like LoneBone stated. Movement in the bushings is normal. If they are rotating in the riser/clamp, that isn't normal and should be loctited and tightened.
Originally Posted by AceRaider
(Post 12631815)
Originally Posted by LoneBone
(Post 12631936)
Thanks all for the help...I'm going to take it back and make sure they tighten the clamp area up and ask about the damper and bushing kit. What type of damper kit and bushings should I get or need?? And would you happen to know cost?
Not sure the info is needed but I have a 2005 softail deluxe.
You want polyurethane bushings.
Originally Posted by Kowan
(Post 12632883)
© 2024 MH Sub I, LLC dba Internet Brands
