Ell as the title says I have a 2009 nightster with 6500 miles. It has screamin eagle slip ons with cycle shack baffles and xied's. I've tested the xied with a dvom and they shot good. The bike surges in 1st 2nd and 3rd and when I'm around the 3500 rpm range it intermittently backfires at a steady cruise. I've checked for exhaust leaked and there are none. I sprayed a wd40 type of lube by the intake manifold gaskets and they seem to be fine. The only thing I found was that the gray/purple wire under the seat (throttle position sensor) was chaffed to bare wire and touching the frame. I patched it up with heat shrink tuning and shot the wire with a dvom to make sure it wasn't broken somewhere in there and it shot fine as well. It's really starting to drive me crazy. Anyone have any ideas on what else could be wrong? Do you think the throttle position sensorr wire grounding itself out could have feted the sensor?
I'd suspect a leak on the intake side, plugs or plug wires, bad elect connection or battery is failing.
Originally Posted by kingomtn
(Post 12644192)
Bump for ideas?
one other thought have you made sure there is no water in fuel.
surging backfiring is really associated with a lean condition |
(Post 12646129)
one other thought have you made sure there is no water in fuel. surging backfiring is really associated with a lean condition
Hey man, get it up to around the RPM range that you feel it surging at and then spray some brake cleaner at the intake junctions. Also sometimes its possible to get bad fuel. Maybe drain your tank and start anew.
© 2024 MH Sub I, LLC dba Internet Brands
