HD Front Brake Master Cylinder
What is the difference in a front brake master cylinder for a single disc and a master cylinder for dual discs?:icon_patriot:
The piston/bore on the dual disk master cylinder is a little larger, providing more fluid being pushed... ;)
Originally Posted by Def Mute
(Post 13045416)
OK-- "some" master cylinders have 11/16 bore---
I was told that some master cylinders are for ABS systems only---how are these different? Bottom line----I am looking for a master cylinder for a project. The project will have dual discs-- if I go to a swap meet, how can I tell which front master cylinder will work for my project? Thanks to all--- Ride safe---lots of idiots out there. |
Im no help re ABS.
Id just find the part number and then research the web for a rebuild kit which should give you the bore spec. I recently got a dual disc master for a cafe bike at 5/8 which came packaged as 15mm |
© 2024 MH Sub I, LLC dba Internet Brands
