will not shift, help
my bike 01 fxstd duce, will not shift to 3rd sometimes then sometimes there is no problem. I have adjusted the clutch and it worked good . Then a few hours later after not riding, I get on and it will not shift to 3rd again. shifts good and feels good in 1st and when I shift to 2nd, the linkage gets sloppy and will not go into 3rd. can anyone help me ? I've been told I need to replace clutch. you info will be appreciated.
Originally Posted by 01hdfxstd
(Post 14370129)
Whoever is telling you to replace the clutch, stop listening to them for mechanical advice, forever... Is this problem occurring while the bike is moving, or just sitting still? Check all your shifter linkages, from the front all the way back. Make sure the shift lever on the transmission is tight and not slipping on the shaft coming out of the transmission. If all this is good, disconnect the linkage to the shift lever at the transmission, move the shifter lever and make sure it springs back to it`s centered position. Keep us posted. |
thanks , All the linkage is good. have not disconnected the linkage and test the spring back yet. what could the problem be if I doesn't spring back?
If it does not spring back to the centered position it could be a broken shift pawl return spring. You would probably have already noticed a problem with the shifter flopping down and not returning to its proper position, but it is an easy check to eliminate one possibility.
Clarify: The shifting problem occours while the bike is moving, correct? You have adjusted the clutch and the clutch cable? |
yes while moving. shifts fine from 1st to 2nd . yes I adjusted both cable and clutch. it doesn't do it all the time
if the linkage is good and free and not binding and it's returning to the center postion it's time to adjust the shifter pawel. get a service manual and it will take you though it step by step. no big deal but you may have to grind down an allen wrench.
Originally Posted by hardheaded
(Post 14372836)
If none of the suggestions works it will be time to lift the top cover from the transmission to inspect the shift drum and shift detent roller assembly. No big deal, except the bike is a Softail, which makes it a pain in the.... |
If the linkage is okay as you say, it may be time to pull the top cover and check the drum/pawl/shift forks for wear/damage...
© 2024 MH Sub I, LLC dba Internet Brands
