ABS brakes
Old 04-17-2016, 03:47 PM
melvinrdm's Avatar
melvinrdm
melvinrdm is offline
1st Gear
Default ABS brakes
can you change your own brake fluid on a 2011 electric gluide with ABS brakes. Any one done it before
Old 04-17-2016, 07:34 PM
Ed Ramberger's Avatar
Ed Ramberger
Ed Ramberger is offline
Just bleed them like normal. At rest, the ABS internals are bypassed and it's just like normal brakes.
The only time you need to use the digital Tech is if the ABS module was replaced and has air in it. The DT tech cycles the internal valves in the ABS to bleed it if it was replaced.
Old 04-18-2016, 07:49 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
It's been done all around HDF! As you have a Glide call in the Touring section to meet many more members there. AFAIK the thing to not do is turn on the ignition at any time while bleeding ABS brakes.
melvinrdm (04-18-2016)
Old 04-18-2016, 08:44 AM
melvinrdm's Avatar
melvinrdm
1st Gear
If the ABS is bypassed does that mean there will be brake fluid in there that won't come out?
Old 04-19-2016, 07:43 AM
kishstl's Avatar
kishstl
kishstl is offline
Yes, but it is a small amount in the ports of the abs module. It won't have a significant effect. Much like the small amounts of oil you have left in the engine during an oil change.
DBLX
12-26-2023 08:21 AM
1Harleyrdr
02-27-2020 12:32 AM
lee123
09-10-2017 08:04 PM
johnxllis
08-14-2017 06:55 PM
casique
12-10-2010 04:03 PM
Quick Reply: ABS brakes
