Octane Booster - what do you use?
My primary bike right now is a 2015 Road Glide equipped with a Stage IV 103 ci engine. With the 10.5:1 compression, the bike has always been finicky about ethanol additive fuels, so I always try to purchase non-ethanol 93 octane fuel. For the most part, this has been sufficient for performance and fuel economy. However, over the past several months, I have noticed what I had thought to be lifter noise between 2,400 and 3,100 RPM. It tends to diminish the longer I ride the bike. My dealer changed the lifters after they heard it. This did not help at all. Now they believe I need octane booster. I'm not convinced this will fix my issue, but I'm willing to give it a try.
I've read about the Lucas Oil octane booster and Liquid Horsepower. Do you have any opinions and recommendations on octane boosters? Thanks in advance for your response.
Received 3,988 Likes
Received 2,858 Likes
Buy a 5 gallon can of toluene (114 octane), add to lower octane gasoline to taste. Check out
http://www.worldofchemicals.com/428/...e-booster.html
Sierra977 (12-31-2016)
ETA Formula 1 racing engines used to run on fuel that's roughly 80% toluene and the rest xylene etc. When they ran this mixture the constructors often ducted exhaust heat to pre-heat the fuel.
Also the gasoline you buy at your local station already has substantial amount of toluene in it, up to 15-20%
Here's an Octane Calculator to determine how much high-octane to add to low-octane to get your desired octane.
http://www.motorsportsracingfuels.co...alculator.html
The following 2 users liked this post by Sierra977:
Norcalsvt (03-22-2018),
shorelasHD (01-01-2017)
