2007 electra glide standard
While it's always good to look for codes, a bad crank sensor typically won't give one.. Low or bad fuel pressure might give a code but might not.. The bike don't have fuel pressure sensors. On an 07, for a historic code to be present, the engine light will on for 4 then go out normally.. If it comes back on and stay on there is a current failure code. If it comes on for a second time there is a historic code that will eventually clear after so many starts.
Well aware of codes and fuel pressure. Of course the bike does not have fuel pressure sensors, that is why a good troubleshooter should have a fuel pressure gauge. They are relatively inexpensive and an easy way to to see what is going on inside the tank of a fuel injected bike.
It takes 50 "trips" without any additional codes triggering, which consists of 50 start and run cycles with the run cycle lasting at least 30 seconds, for the ECM to clear any historic codes. A crankshaft position sensor can throw other DTC's but there are two codes in the database specifically for the crank sensor.
Anyone can throw parts at a problem, but if you take your time and just start with the basic, simple, stuff I feel anyone can accurately troubleshoot an issue. And yes, sometimes that "troubleshooting" involves throwing a good ESTIMATED guess of a part at the issue, not just throwing all kinds of different parts at it.
These basics include:
checking codes and
checking fuel pressure in this particular case
ALWAYS:
KISS
Keep It Simple Stupid
Also wanted to add that I have rarely seen a crank sensor magically fix any particular issue. Although they are electronic and do fail on occasion, it is a rarity that they do. Sometimes they just need to be cleaned and most other times there is something else going with the bike. whether it be electrical or mechanical.
In either case random stopping without a code is more than likely the crank sensor or fuel issue. It could also be run stop switch. The warm failure characteristic is indicative of a cranks sensor. It could also be something as simple as a poor fuel line connection at the fuel tank..
Add:
Another thing to look for when the motor stops is what the engine light does. It needs to still come on for 4 seconds and go out. If it does not do that, then ECM may be the heat related failure, providing it is still getting power. .
The bike has a 103 in it. It was the first year for the 103 in a police bike. I changed the fuel pump this weekend but, the problem still persists. I am going to the local Harley dealership on Friday to pick up a new ckp. Hopefully that fixes the problem.
New coil, battery, fuel pump and, a new ckp. Hopefully I can get this problem resolved before to long.
Well it was a shot.. Does the behavior of the engine light change when the bike quits?? It should come on for 4 seconds then go out... When it quits, if you cycle the ignition, can you hear the fuel pump run.
Stop just throwing parts at it. TROUBLESHOOT the issue. Listen to the wonderful advice you are receiving from several people in here. It's a simple issue that is just waiting for you to discover.
Have you checked your codes if any?
Do you have the capability to measure your fuel pressure?
