General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Every battery I've seen/used has posts molded in battery casing so I'm going to say it's a no. What melted the post...was it faulty battery, or self-inflicted wound?
Damn man, I'd probably replace the cables too. That kind of heat can travel down the cable and damage a lot.
I agree. Replace the cable that overheated. The terminal end is I'm sure damaged under the insulation. It will be a high resistance now and cause charging problems.
