1990 sportstwr 883 brake rear rotor disc
Hi,
i removed the rear wheel to sand and polish since it is a solid rear aluminum wheel and it has that raw aluminum cast finish on it. Should i use red loctite or blue? Also what are the torque specs and i was told the bolts should not be reused and to get new ones. Im having a tougj time locating new bolts. Also i may have the axle put back by someone who knows more. A friend of my friend once replaced his wheel beari bearings in his car and tightened it too much and it seized up and the wheel came off. That is my fear of not doing the axles right Please help!
mjmckee53
05-29-2011 10:57 AM
