Harbor Freight Motorcycle Lift
#41
I finally got my HF lift converted to air/hydraulic like i wanted. It's a HF 12 ton air/hydraulic jack. I had to make a plate with a 5/8" rod welded in the center so it would swivel as the jack went up and down and brackets to hold it. It works great and raises the bike way faster than the foot pump did with a whole lot less effort. I still have not got the metal to make some outriggers to make it where it won't tip over or tip forward just in case it happened to, but i'll get that done fairly soon.
#42
I'm not sure about the lower setting, but your bike (FLHXS?) on the fully extended lift will require roughly 86" of headroom. Maybe someone will chime in with the difference between the locked settings.
#43
#44
