Using vinegar to remove rust from gas tanks
well like was brought out, vinegar (sour wine) is mildly acidic. it makes a good metal prep for painting. it will also dull roofing tin. i remember one time offshore, i repaired a roof over a compressor skid and it was so blinding that the helicopter pilot was pitching a fit while trying to land on a nearby helipad so i had to spray it down with vinegar.
will it produce rust, well yep, it is largely water and if left on metal, it will oxidize it.
It depends how bad the rust is. my 94 fatboy was filled with rust. I tried the vinegar over night and it took a good bit out, pieces that were smaller. Repeated the process and i thought that i had gotten it all out from what i could tell. Ended up using acid and that cleared everything out in a few minutes. It ate the paint though because it was muric acid ( was planning to get paint anyway). But ended eating everything out and had a local shop coat the inside of the tank and then all was good.
