Annoyed, need help with ECU
well, looks like a new firmware was installed which inhibits the read/write line or sometimes an erase pin from being accessed so you would have to go back to the program that installed it. the other option would be going internal to the devise, but you would have to know the parameters needed as there are many. once inside, with the correct pinout, you could manually apply the correct voltage to the pin to force it to the programming state and then try using a programmer to flash the data.
removing data by removing power depends upon the memory itself. once you remove power, the little bugger transistors become like capacitors and can hold state for very long times, unlike volatile memory.
if hd couldn't do it and you can find the source, looks like a new ecu is in order.
oh i love gravity fed machines!
appreciate the advice none the less.
do i have a leg to stand on here? I mean they should take responsibility right?
"ECU calibration ID" DWA61705-000 i your screen shot indicates the bike was flashed with a TTS calibration. You have to get the TTS box from prior owner or who ever flashed it and may have it to return the OE calibration. TTS locks the ECU once installed, but can be returned. The other option is to send your ECU to Mastertune and have it re-flashed to stock. Or worst you buy a new ECU from HD.
I just called tts, and they cinfirmed its a mastertune code, appreciate the knowledge here guys, thanks a lot!
Will do... In case the dealership cant unlock my ecm and doesn't want to help get it sorted, do i have any recourse? Would HD Canada take my side on this? Anyone dealt with something like this already?
i would think its their responsibility to either give me the tts tuner that tuned my bike or unlock it, or worst case, replace it.
