Antiseize - Copper vs Aluminum?
The spark plug manufacturer will say no anti seize because they already have a sacrificial coating on the threads, but the service manual will tell you to use anti seize...
I don`t use it on new spark plugs, and very sparingly on used plugs, and torque to minimum spec.
do not use a metal base on spark plugs, the mixture can cause seizures believe it or not. the thermoplate will work but it is recommended a product like BG graphite be used, this is what an industrial engine needs. any anti-seize on plugs should be one spot two threads down on the electrode side. in a highly used machine with short plug life, recommended to clean the hole threading.
the big issues is if the plug seal goes south, the hot combustion gases can carbon the metal base carrier which can include even clay.
https://images-na.ssl-images-amazon....L._SL1118_.jpg
https://www.hdforums.com/forum/dyna-...ml#post8555487
Received 8,247 Likes
