Antiseize - Copper vs Aluminum?
Have aluminum...have used it for years but in a recent video on car brakes, they were using copper.
I get the brakes application is high heat but wondering otherwise, are these 2 essentially interchangeable? or is one 'preferred'? (not just for brakes).
Would rather keep 1 product around vs 2 if possible.
each has their own +/-'s
the product i use is thermoplate 220 made by chemola out of beaumont, tx.
it will go from the flame bucket of a launch to cold of space. if you take a torch to it and burn it it still lubes.
i ran across this stuff working on relief valves for oil & gs production vessels
i can tell you stories about this stuff
there is one cravat however. this stuff will plate the actual parts and cannot be used in tight tolerances. there is a work around, mix 50/50 with grease. this stuff if highly water resistant and i pack wheel bearings with the mixture.
https://socousa.com/index.php/desco-...rm-o-plate-220
you must not over pack this stuff as it is so slick, the ball will pass through it and not carry it around, aka, another reason i mix with high quality grease. for brake pins, use direct, thin film.
F150HD (10-06-2018)
In video they actually called it "copper grease"- maybe thats a UK thing (?)
I use the copper anti-seize on the exhaust pipes (slip-ons) when I re-install them after a tire change. I know instead of removing the exhaust I could just remove the shock bolts and lower the swingarm, but I'd rather not risk stripping or causing any type of problem with the threads in the shock mount/frame.
F150HD (10-06-2018)
The spark plug manufacturer will say no anti seize because they already have a sacrificial coating on the threads, but the service manual will tell you to use anti seize...
I don`t use it on new spark plugs, and very sparingly on used plugs, and torque to minimum spec.
