Motion Pro bearing removal tool ?
Motion Pro 08-0410 on eBay
The Pit Posse version is slightly cheaper even with adding in the extra 25mm collet
Just a thought ...i used the collet that came with the cam bearing remover/installer tool I bought...same size on bike and I made a receiver cup at work out of a piece of pipe and a welded a big washer to the end of it and then used a 12" long piece of 3/8" threaded rod with some more washers and a couple sleeve nuts...i realize not every one has access to all the equipment but just trying to throw out some ideas.
