CVO 255 cams
Old Dec 22, 2018 | 04:31 PM
Oldfart666's Avatar
Oldfart666
Default CVO 255 cams
Thought I had posted this earlier but can't find it.... I pulled my cam plate to check what cams were in my 2009 Road King. The cams were stamped CVO 255. I pretty sure these were not in the '09 King. Some say these are same as Screamin' Eagle 255's ,some say not. Do these give a performance boost from stock (the SE are, but if factory later model cams do they still)
Old Dec 24, 2018 | 10:25 AM
Ed Ramberger's Avatar
Ed Ramberger
All H-D cams stamped 255 have the same specs.
Old Dec 25, 2018 | 08:55 AM
jmeyer58's Avatar
jmeyer58
The 255's came in the SE 110 motors. Nice cam for low end torque. Other cams will give higher numbers but it will be higher up the RPM range. I like the 255's but I am getting a lot of weight going off the line and not interested in drag racing.
Old Aug 4, 2021 | 01:38 PM
Infini's Avatar
Infini
6th Gear
Stock cams on lets say a 96ci give about 66hp if I'm not mistaken. The CVO 255 I believe give about 86 and 94fp torque. Great improvement to the regular cam considering. Higher the compression I'm sure there will be changed to all those numbers.
VTL nut
Sep 21, 2012 06:47 AM
1Chief
Mar 30, 2012 08:49 PM
Straycat
Jul 24, 2011 05:16 PM
waynemags
Jun 3, 2010 10:28 AM
racerdave
Oct 18, 2009 03:37 PM
