2019 Streetglide special
Just finished installing 12 " bars on my street glide everything went smoothly until i put the ignition switch back in , i know i have gotten the tumblers out of whack have a tool coming to reset . Dont have dash lights , horn , power on ignition on /off switch . Harness pulled smoothly through both side if bars don't believe I damaged any wires . Would tumblers out of set cause these issues ?
well based off my lock picking, the tumbler pins have nada to do with the switch contacts. basically, you have holes and pins which must line up for the cylinder to turn. if one pin sticks up, it will not turn. now that said, how did you get them out of wack as you said, did you open the cylinder? perhaps i am not reading between the lines?
double checked all connections again this morning no cut , pinched wires or loose pins . fuses ok , have power to the radio , no control from thumb switches no dash lites no turn signals or brake lites no power to the on / off switch you can hear the fuel pump kick on
reinstalling the switch in the tumbler i just screwed it up & now its all misaligned have a tool coming to help with this would this cause all the above ?
Tris S
General Topics/Tech Tips
05-15-2019 11:06 AM
crawfordcl
09-15-2010 10:52 AM
MoonCricket
02-28-2010 05:49 PM
