High idle issue (3500rpm +)
Old 01-10-2019, 02:58 PM
Bambam757's Avatar
Bambam757
Bambam757 is offline
Stage II
Default High idle issue (3500rpm +)
I have a 2012 Ultra classic, I just finish rebuild motor, handlebars install. I start bike and it’s a high rev as if the TGS was either upside down or the wires were wrong. I checked the wires and there were good. So I kept the TGS unplugged and started the bike, and the same high rev of the motor is the same.... in lost and could really use some help
Old 01-11-2019, 01:34 PM
Zanthamos's Avatar
Zanthamos
Zanthamos is offline
Is the IAC moving? If not check the wires there.
Old 01-17-2019, 07:55 AM
dyna50's Avatar
dyna50
dyna50 is offline
Did you fix the issue? I had a high rev issue one time when I lifted my tank to check something, I ended up disconnecting the IAC plug at the IAC... I cursed myself for a couple and then realized it was just the plug loose.. I wouldn't try to start the bike with anything unplugged like the TGS sensor though... Like Zanthamos said above, the IAC could be clogged or not moving at all..
Old 01-28-2019, 08:43 AM
Magnut1's Avatar
Magnut1
Magnut1 is offline
Received 1,679 Likes on 822 Posts
If you had any back fire after rebuild, trying to get it started, you might have blown off the purge tube cover. It is behind your intake, a small nipple sticking up that should have a rubber cap plug on it. It has something to do with Cali smog but 49 states just cap it off. #11 on the diagram.
Old 01-30-2019, 04:47 PM
Dylgar's Avatar
Dylgar
Dylgar is offline
Stage I
If you just had the engine rebuilt could be a bad intake seal if you had the manifold off
Bambam757
01-10-2019 04:08 PM
asafrank
04-03-2014 06:41 PM
photocycle
11-18-2011 04:03 PM
jacknthebox
09-05-2011 01:16 PM
BiggestDawg
07-26-2005 01:37 AM
Quick Reply: High idle issue (3500rpm +)
