Stripped screw!
This is the set that I use for a situation like that.
https://www.mactools.ca/en-ca/NoValu...-Extractor-Set
Received 6,044 Likes
Received 47,780 Likes
Use a drill bit to "remove" the head of the bolt ... Might be able to remove the remaining protruding bolt with a pair of vice grips ... If not continue with drill and screw extractor ... There are many types ... I prefer this set / type
Similar models available through places like Harbor Freight for economy buyer
Hey Man (03-13-2019)
Drill the head off and vise grips, heat the end with a pencil torch first to soften the loctite. As you've seen lots of choices on easy outs, I've got most all types but these are my goto's 90% of the time ,
Real hard to break one of these for the beginner mechanic compared to the long versions
