Ballpark cost for camchain tensioner mod?
That’s a loaded question. Dealer probably charge 1 hr to check the tensioners. If they’re bad, and they replace only the tensioners and bearings, probably charge 3 hrs plus parts. To “mod” them as you say, I assume you mean replace with hydraulic or gear? Doing that requires new cams and potentially a tune.
$1200??
In my book, that's a sizable expense! If ya put that on top of what they're asking for 88 bikes, ya may as well just buy a 96?
IDK, maybe I'd be better off putting this idea off til next year, and getting a newer bike. I'd get a new one if I could part with the fxbr, but I just can't do it, lol.
I had the SE Cam Chain Tensioner and Oil Pump Upgrade done at 30k, when I developed a base gasket leak. I love it. My bike runs like a Dynamo now. Oil psi went up about 15 psi.
You don't need to do it until 30 K. If you mostly run 2 lane stick with the 88. If you run interstate a lot over 75mph, a 6 speed/>88 would be better.
If you find a low mileage 88, you won’t have to do the upgrade for several years. You don’t need a new cam, I didn’t. But if you want one, that’s the time to do it. Was about $300 more, in 2014.
If you find a bike that had it done, it’s probably going to gave higher mileage. If it’s a well maintained bike, it might be a keeper.
I found a 2003 Road King with 1500 miles this year, for $6,900. It was a Fireman’s bike, used only in parades. I didn’t buy it, but they’re out there. Prices are much better in January, than June.
I was doing new cams. After looking into it some, I bought a used camplate and oil pump out of a newer 96 inch bike. It bolted right in. Be advised that it will require a cam change, since the inboard bearing is 3/4" od, while the outboard side uses no bearing at all and is 1" od. I personally went with an Andrews cam for this application (the N series, 21N in my case) but I'd bet of cam manufacturers offer one as well. I did all the work myself and my total cost was around $500 including the cams and new S&S lifters and a top end gasket kit. I reused my stock pushrods to save some money even though it was a little more work to do that.
Haven't called and checked. Was on here late one night and though "what the hell, I'll ask the guys". I realize prices will vary. I'm not an engine mechanic, but very mechanically inclined. Thought alot about doing it myself if needed. Maybe the inspect, but mod or cam changes a lil out of my comfort zone. I'd love to though. Rewarding.
