Wheel spacers on aftermarket wheels.
I posted this problem in the wheel and tire section but got zero replies so I'll try it again here. I've got a 99 Heritage Softail and I just bought some fat spoke wheels to put on it. I don't know how to go about sizing the wheel spacers properly. The wheels are calling for an end play measurement of .004-.018, which is pretty tight. Do you just center the rotor in the caliper and measure from there? What about the front axle? It has a built in spacer in the dog bowl on the right side. I understand that people mock up the spacers using PVC pipe, but will I need a large to cut the real spacers down to the correct lenght? Who has personally done this and can offer some insight?
the best way to set this up is to install the wheel and brakes with no spacing. once you center everything out on the front, then string line it to see if it aligns with the rear. there is some wiggle room but keep it close as you can. then you can use a caliper or a stack of feeler gauges to see what you need to each side.
the type of hub makes a diff. is it using tapered bearings or ball bearings?
wheel end play is the amount the hub is allowed to travel along the axis (axle). this has nothing to do with the above spacing. this is set via spacer internal to the hub. when the entire assy is tightened, the spacers, inner bearing race and internal spacer will clamp down to a solid fixture. any end play will be in the bearings and the lower end of the allowable amount is better. sealed ball bearings are pretty much a no brainer since you really cannot adjust them, however, the taper bearings are adjustable via the internal spacer.
hard to engineer over the net.
do you have a caliper with a depth rod?
the 1" & 3/4" bearings should be the same width and if not record the diff. the diff will be added or subtracted from the inner spacer. the inner spacer should be a drag fit between the two inner races. if the 1" is installed, use the depth rod to get outside to outside inner race surface, you can use this info to adjust for the 3/4", the outside races should be shouldered in the hub. if this setup is for the app, then they should be good to go. you must get the inner spacer correct before sizing the outer spacers.
have you youtube the operation, it might give you ideas.
