Bike Alignment
Old Nov 7, 2023 | 06:44 AM
Rob Harper's Avatar
Rob Harper
Another crude method is remove seat and put level across, then another level on the rear brake disc. They should be perpendicular.
Old Nov 7, 2023 | 09:53 AM
enginemounts's Avatar
enginemounts
"Alignment" is a term that gets thrown around loosely. It is subject to misinterpretation and misapplication. The video mainly talks about equalizing the shock length. Equalizing shock length is not alignment. There is no technical reason to align the motor to the frame. Anything that may cause forces to be exerted on the motor mounts is not recommended by Harley.
Old Nov 7, 2023 | 11:45 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by touchdown
Just what I need another thing to screw with. Oh boy I can see posts coming. Why is my bike only left turns and so on
You were right.. Here we go...
Old Nov 7, 2023 | 05:58 PM
Timberwolf2017's Avatar
Timberwolf2017
I don't know about what he is saying, but I would think tweaking the engine to one side could cause other issues. I do know my RG Limited will always go left if I let go of the bars, it immediately starts leaning left.
Old Nov 13, 2023 | 10:17 PM
OakMountainRider's Avatar
OakMountainRider
Originally Posted by cj24
Interesting, what do you all think about this?
https://www.google.com/url?sa=t&sour...jQ5ON62Gaw47yS
I remember the subject is described in the manual. (By the way, I didn’t know that the top engine link was not adjustable after 2009.)
As someone has mentioned in this thread you can also use the brake rotor. One way that is described in the manual is to remove the top link, start the engine and run it for a while, then adjust the link to the position achieved.
Then if the rotor is not straight you may adjust the link, I think 1-2 turns or so. (Not sure about the amount of turns.) Manual states that too much adjustment may cause vibration.
Anyway this is an interesting subject and I did not know about this method. Maybe it is good, but you will need the tool he has.
Next part is of course alining the front fork, which is also interesting.
There is another problem whith the Dyna, which comes when you pull the throttle in corner or a bend and you get out of balance. What helped me there was replacing the stock front motor mount with the Predator mount. The bike may vibrate a bit more between 2000 and 2500 RPMs but it will be rock steady when you accelerate out of turns. (My experience is that the additional vibration caused by the Predator can be reduced by adjusting the timing.)
Also one important thing. That is having correct tire pressure.
Old Nov 13, 2023 | 11:31 PM
MotoJockey's Avatar
MotoJockey
Tha tool he has made is pretty much just a "Go-No Go" tool. There are plenty of ways to make something to check what he is checking, including using one of 5 tape measures that I own. The adjustable Heim joints is the thing I'd like to get. Just to play with it. I see some for cheap online right now.......................
Old Nov 14, 2023 | 09:49 PM
96hugger's Avatar
96hugger
You have a point for sure. With both of my bikes I dont notice any alignment issues. Now with the FLDE I once had there was something off.
This is because your motor-frame alignment will affect your swingarm alignment, and if your shocks are attached you will not be aligning the motor because of the tension from the shocks.
Replied to wrong quote.
Old Nov 14, 2023 | 09:56 PM
cj24's Avatar
cj24
What I meant by something "being off" ... was perceived non-alignment when riding the bike. Partly attributed to my handlebars seemed crooked while going straight down the road. Despite dealers saying all was good ... nothing wrong with it. BS ... i dont have that feeling with 3 others bikes I have owned. I adjusted my bars, installed poly risers etc.. the same. But for sure did not attempt or consider motor alignment.
Old Nov 15, 2023 | 01:11 AM
OakMountainRider
I have one. I replaced the stock top motor mount with it because it has rubber in it. (I think it is called VelvaRide, but not sure. There are several brands I guess.)
Anyway I think I will try the method described in the video this winter; measuring the distance between the upper shock mount and the swing arm, while the schocks are disconnected and the rear wheel is off the ground. Never tried that one.
Old Nov 15, 2023 | 09:45 AM
MotoJockey's Avatar
MotoJockey
Googled it and found this, but all sold out................ I like the concept if the plunger action tho.
https://www.luckyspeedshop.com/produ...t-stabilizer-1
