Quadlock wireless cabling for 2013 Fatboy
I am installing a Quadlock wireless charger cable from my battery to the bars. Do I need to remove the tank to feed the cable between these two points? If not, how should I feed the cable?
(I have a 2013 FLSTF) |
Run it over the top and secure it with duct tape.
I was able to feed thin wires under my tank without removing the tank. It's easier if the bike is up on a motorcycle lift.
I run mine under the tank, but I would imagine you could run the wire under the console.
Removing the tank to run the wire is not difficult. Just make sure the tank isn't full when you do it......It's about a two-beer job with minimal skill required |
Do I need the special hose to empty the tank, and the special clamps for the fuel line?
© 2024 MH Sub I, LLC dba Internet Brands
