View Poll Results: What more important?
Oil Temp
25.00%
Engine Temp
12.50%
Neither
62.50%
Voters: 8. You may not vote on this poll
Koso Gauges
Old Apr 3, 2025 | 10:53 AM
Glenn Gorman's Avatar
Glenn Gorman
Default Koso Gauges
Well the easy part is done. That is installing the gauges. Now comes the hard part, configuring the gauges for my bike. These even came with an Oil Temperature Sensor. But, it gets installed in the oil drain hole. I have 14,000+ miles so looks like an early oil change. If you don't use the oil temp sensor, the gauge will show engine temp.
Question: What's more important to you, Oil Temp or Engine Temp or it doesn't matter?
Old Apr 3, 2025 | 11:27 AM
Goose_NC's Avatar
Goose_NC
oil temp at the tank will be lower than the engine temp. Most people will freak out learning the temps that the motor routinely runs at.
Old Apr 4, 2025 | 11:17 AM
Max Headflow's Avatar
Max Headflow
Either is fine..
Old Apr 4, 2025 | 11:57 AM
luckiestiff's Avatar
luckiestiff
this! I had a fairly built jet boat that I had planned on putting a blower on so I ordered a boost gauge, blower didn't happen so I swapped the boost with oil temp, I spent that weekend freaking out over oil temps. I put in a clock when I got home.
Old Apr 4, 2025 | 12:44 PM
MotoJockey's Avatar
MotoJockey
The logo for the Union that I retired from is a gauge, lol. Been reading them for years and actually fond of having the knowledge that they give me. Very helpful sometimes! That being said, I wanted BOTH, oil and engine temps, so I went with Dakota Digitals. Not to mention that I had an issue with some Koso Gauges and their customer service in Canada sucked ***.
International Union of Operating Engineers - Wikipedia
Old Apr 8, 2025 | 06:02 AM
Kenny94945's Avatar
Kenny94945
I voted oil temp.
The reason is that I typically only see specifications for oil temperatures.
With oil temperature, one knows when the engine is warmed enough to redline.
Ditto would know when overheated in traffic.
I don't recall ever seeing a spec for engine temp.
Plus, the engine temperature may vary from front to rear, side to side, and top to bottom... depending on the sensor location.
Slingshot56
Nov 6, 2019 10:29 AM
BornTexan
Mar 2, 2014 07:13 PM
pontiac69
Aug 10, 2011 08:52 AM
Eric Moore
Aug 23, 2009 05:56 PM
Motorman10
Sep 6, 2008 05:54 PM
