Trick to removing starter w/o removing oil tank?
Got a 2008/2011 Softail. Does anyone have a trick to removing the starter without having to remove the damn oil tank?
If you've wrenched it before you know there are two bolts that hold it to the back of the inner primary. The front bolt I can get to relatively easily..but the bolt under the oil tank is a bitch! I can't get at it straight on with an extension because of all the crap under the oil tank (lines, etc). And if you take the battery out and try to get at it from above you can't get any stroke.
If you have a trick to getting it off without removing the oil tank, I'm assuming it involves some kind of angle socket with an extension...please be specific on your tools!
Thanks!!
D
Thanks!!
D
Chopperbob (08-08-2021)
The easiest way is to pull the tank, not that big of a deal. You will not get the starter out without removing tank.There's a couple of bolts on top of tank and couple of bolts on the back of tank. To get to the bolts on the back of the tank, you'll have to remove the inner fender. Remove the two oil lines on top of the tank via quick connectors under the chrome covers. Just slide the covers down on the line, revealing the connectors. . Remove the feed line on motor via quick connector. You'll have to cut the clamp off the drain line on bottom of tank. Replace with hose clamp. Make sure you drain oil first. Just be happy you don't have a 2006 and older bike. Those you have to pull primary cover off to remove starter.
One of the BIG obstructions is the battery support plate at the bottom of the oil tank. If that was not there, I think you could lift the starter out right through the battery space. I am thinking that the next time I have the oil tank out, that bracket is going to disappear. I'd rather make a support plate with ears that rests on the TOP of the oil tank, so you can lift out the battery, and lift out the battery support, and get full access to the starter.
98hotrodfatboy (03-19-2020)
